Starting Modeling PE without default Part and Workplane
Not applicable
By default, CoCreate OneSpace Modeling PE starts with a default part (named 'P1') and workplane (named 'W1') Workplane 'W1' is located at the World Origin (0,0,0) with the U axis of the workplane aligned with world 'X', the V axis aligned with world 'Y' and the W axis aligned with world 'Z' Some users do not wish to start modeling PE with these defaults. (for instance, when loading in existing models, or when importing from STEP or IGES) To turn this setting off, select Edit-->Settings-->System Settings. Go to the Startup tab. Uncheck ""Create default part"" and/or ""Create default workplane"". Now, when you restart CoCreate OneSpace Modeling PE, or start a new session, you will no longer have the default part and workplane.
