Windchill Attribute from Modeling to Annotation
Behnam
6-Contributor
I'm currently setting up CED to work with our Windchill setup. While I have successfully set up the tree browser to show and pass attributes to the Workgroup manager, I'm having no such luck with passing those along to the Annotation module. By manually copy/pasting the values through the attributes menu in the Workgroup manager, we are able to fill in our title block in Annotation.
My question now is, if it is possible to somehow pass the attribute values from Modeling to the title block in Annotation without manually having to copy/paste the values in the Workgroup manager?
uai
9-Granite
9-Granite
(To:Behnam)
Hi you'd usually do this with a download delegate in windchill, that adds the attribute from the Model to the drawing when it is downloaded.
However it requires some customization of windchill
Behnam
6-Contributor
(To:uai)
Hi, we solved this with some LISP code within the Modeling session
