parametric 2d
ptc-2531671
parametric 2d
can i do parametric 2d. i dont mind if it is not as polished as solid edge. all i want is to define some basic relationships between 2d elements. thanks
Not applicable
(To:ptc-2531671)
The 2D copilot will dynamically infer relationships while drawing. However, those relationships aren't kept in the model. If you need persistent parametric relationships, you can add them in 3D. (Most of this functionality is available in the commercial version only, though.)
