"PD_ZONE" info messing up with macros
Garnet
Dear all,
on recently installed Workstations, Direct Drafting 19.0 began to add to drawings the info "PD_ZONE".
This is not present in drawings created by other Workstations and is messing up with macros, probably because it is the first info read by an INQ.
I can certainly provide some "PD_ZONE" cleaner utility, or lines that ignore it, but the main goal is to inhibit its creation.
I believe this issue could someway deal even with the problem reported in my previous topic "Unpredictable macro crash".
Thank you for reading!
Sorry everyone!
Do not consider, unless it could be useful for you. The solution is the simplest: Settings>Edit Ambient>System>Ambient-Parametric design module unflagged.
Nothing to do, anyway, with the previous topic, still unsolved.
Marco
Tags (2)
