Hi There,
I'm looking for the variable that limits the Model Manager search Results to 2,00 results. I would like to change this variable to a larger number for a particular search. Any info is greatly appreciated. TIA!
-john
From the customization guide:
Section: | Options |
Required: | Yes |
Value type: | Integer |
Default: | 1000 |
Product: | PTC Creo Elements/Direct Model Manager, PTC Creo Elements/Direct Drawing Manager |
<QueryLimit>500</QueryLimit>
Thanks Max. Can you tell me where the custom.xml file is located?
your XML file is located in the %APPDATA% directory.
From the type of questions I recommend you let your Administrator do this - if you have one.
