Add multiple guides to a Creo Illustrate 6.0 annotation
Amethyst
Ciao a tutti,
come faccio ad aggiungere una seconda linea guida a un'annotazione (Nota con linea guida)?
Grazie ,
Matteo
Re: Add multiple guides to a Creo Illustrate 6.0 annotation
Hi Matteo,
If the item list is not important this can be achieved using the "User Defined" callout type.
First create a user defined callout on each part, then select the items in the item list and in the Item list ribbon select the "Group" option.
This create a single callout with multiple leaders, then you simply double click the callout to edit the label text and type in the required text.
This does result in a single label with multiple leaders but the item list will reflect the grouped items so this may not be the result you need.
Hope this helps
thanks for the reply but
what I want to do is add a second guideline to a note with text (see example image)
Thank you,
Matteo.
Unfortunately this is not possible for notes at the moment.
It may be worth logging this as an idea here:
https://community.ptc.com/t5/Addtl-Creo-Ideas-Creo-View/idb-p/creogeneralideas
As I can see many usecases for wanting to be able to do this.
