Add multiple guides to a Creo Illustrate 6.0 annotation
Matteo_1987
Ciao a tutti,
come faccio ad aggiungere una seconda linea guida a un'annotazione (Nota con linea guida)?
Grazie ,
Matteo
Hi Matteo,
If the item list is not important this can be achieved using the "User Defined" callout type.
First create a user defined callout on each part, then select the items in the item list and in the Item list ribbon select the "Group" option.
This create a single callout with multiple leaders, then you simply double click the callout to edit the label text and type in the required text.
This does result in a single label with multiple leaders but the item list will reflect the grouped items so this may not be the result you need.
Hope this helps
Matteo_1987
(To:agarland)
thanks for the reply but
what I want to do is add a second guideline to a note with text (see example image)
Thank you,
Matteo.
Unfortunately this is not possible for notes at the moment.
It may be worth logging this as an idea here:
https://community.ptc.com/t5/Addtl-Creo-Ideas-Creo-View/idb-p/creogeneralideas
As I can see many usecases for wanting to be able to do this.
