CREO View Express
ptc-4754653
CREO View Express
Modelle werden nur als Drahtmodell dargestellt.
Gibt es eine Möglichkeit dies zu ändern?
(Das Umstellen über den Rendermodus ist nicht möglich)
7 REPLIES 7
Johann,
maybe your model was saved with config.pro option SAVE_MODEL_DISPLAY WIREFRAME.
Look into your config.pro file and change the setting of SAVE_MODEL_DISPLAY option.
Allowed values:
WIREFRAME
SHADING_LOW
SHADING_HIGH
SHADING_LOD
Then restart Creo, open model, save it and open in Creo View Express.
Martin Hanak
Martin Hanák
Hello Martin,
thank you for your information, but i want open older models with the viewer and can't open it with Creo!
Johann,
if you cannot re-save the model (you can do it in ProE version, which was used to save the model), then you cannot see the model in Creo View Express as shaded one. This is because the model does not contain such information.
Martin Hanak
Martin Hanák
Good morning, Martin!
i'm afraid so but for what is it good.
The Program is inoperative!
Johann,
I am sorry I do not understand your last message.
Martin Hanak
Martin Hanák
ich habe es befürchtet und frage mich, für was soll das Programm gut sein.
Das Programm ist unbrauchbar
Q: but for what is it good?
A: CREO View / CREO View Express are viewer for the graphics information.
In order to show something, graphics information needs to be saved with the model.
They cannot regenerate the graphics information based on the features saved in the model, as Creo Parametric can.
