Callout Partnumber Annotation in Creo Illustrate 2.0
Level 1
Is it possible in Creo Illustrate 2.0 to change the attribute in the Callout Partnumber Annotation from "PARTNUMBER" to some Parameter that is existing in my Creo prt files?
I found in the C:\Program Files\PTC\Creo 2.0\Illustrate\resources\pvplugins\galaxystartup\text\resource\CalloutTemplates.xml
Line 122          <useproperty category="PROE Parameters" name="PARTNUMBER"/>
but the change is not used, since a dll is precompiled and thus the changed option is not used.
Does anyone know a trick or how to use other Parameters in Annotations?
