Can I customize the tree of the sBom in CREO Illustrate ? (Add columns)
Highlighted
I use CREO Illustrate 3.0 M030, and I would like know if it's possible to add any columns in tree model for sBom ?
If I can add information like Parameters of model, System Variables or anything.
I would like to customize model tree of sBom like CREO Parametric with any infomations in columns.
Do you know if it's possible ? and how ? tutorial ? video ?
8 REPLIES 8
Re: Can I customize the tree of the sBom in CREO Illustrate ? (Add columns)
Hervé,
I don't believe that it is possible. To be sure, please ask PTC Support.
Martin Hanak
Martin Hanák
hello Hervé,
it is an option available in CREO VIEW only:
cheers
Ron
Seems like its only available in the "Item List". There is a button in the ribbon where you can add attributes to the item list.
Unfortunately you can't.  And you can't customise the structure view like you can in Creo View as Ron showed.  You might want to vote on this idea to get that in:
Creo Illustrate modeltree
Hello Hervé,
Like in CreoView (ronan idea), you can did it in CreoIlustrate :
Exactly
Thanks, it's exactly that I want.
Great
Just note that you can only do this in Creo Illustrate 3.1.  It was a new feature that they added in.  Pity they haven't marked my idea as implemented.
