Coordinate Locations from Model
Highlighted
Level 1
I have a rectangle modeled up that is 10mm by 10mm. I assemble this into
an assembly with a coordinate system located at the upper left of the
rectangle. I am looking for a way to report, or display on the model,
the center of the rectangle based on it's location from the coordinate
system in the assembly. I tried to attach a jpeg to help illustrate what
I am trying to do but it made the file to large for the exploder. I can
send it separately if needed. Is there an easy way to do this? Thanks.
