Has anyone setup Illustrate in Windchill?
Level 8
I need to add Creo Illustrate to my existing Windchill system but I cannot find any documentation to talk me through it. Does anyone have some documentation I can access or is there some on PTC site?  Or is this a project for a 3rd party?  Any assistance is appreciated. Thank you.
Tags (1)
Re: Has anyone setup Illustrate in Windchill?
maybe you can start at https://support.ptc.com/appserver/cs/doc/refdoc.jsp page and look for:
In result list you can find ... PTC Windchill Workgroup Manager for Creo Illustrate Administrator's and User's Guide  - English
URL of this guide is http://support.ptc.com/WCMS/files/168666/en/WWGMCreoIllustrateGuide.pdf
Note: I know that this exists, only. I have never used it and I do not have any experience with Creo Illustrate + Windchill.
MH
Martin Hanák
Earl,
You need a few parts to get it installed / configured.
As Martin said, you need WWGM.
But you also need the Illustrate WWGM Illustrate licensing which you should be able to get from your Account Rep.
You also need to configure visualization Post Publishing to create GDD CAD documents with the PVZ.  You can find info on that in this doc
http://support.ptc.com/WCMS/files/157363/en/WindchillVisualizationServicesGuideWC10-2_M030.pdf
In the section labeled "Creating Arbortext Documents from CAD Documents"
David
Creo Illustrate 4.1 F000 you can have a direct connection to Windchill w/o the need of a Windchill Workgroup Manager. We are currently pursuing this option since all the preferences including Windchill and license server can be rolled out in the admins_pref file with the installation to our users.
