How create .pvi file from sequence in Creo Illustrate?
SOLVED
I created a sequence in Creo Illustrate and want to import it as .pvi file in Vuforia Studio, but I do not know how to do it.
Someone knows how to create the file .pvi ?
Thank you very much for your help.
Re: How create .pvi file from sequence in Creo Illustrate?
Greetings,
Once you publish your sequence and generate the .pvz file, you will need to copy that file and rename the copy to become a ".zip" file. You can then extract the .pvi file from the zip file. However, while this is the official method I've been getting odd results.
Source:
Vuforia Studio Enterprise
Greetings,
Source:
Another question is what if you are leveraging an animation (not a sequence)?  A *.pvi does not appear to be created.
Thoughts?
Greetings,
Thank you very much for your reply, I've also been getting odd results.
I can use another format other than PVI for animation, some other developed for example in unity??
