How create .pvi file from sequence in Creo Illustrate?
framirezsalaman
I created a sequence in Creo Illustrate and want to import it as .pvi file in Vuforia Studio, but I do not know how to do it.
Someone knows how to create the file .pvi ?
Thank you very much for your help.
1 ACCEPTED SOLUTION
Greetings,
Once you publish your sequence and generate the .pvz file, you will need to copy that file and rename the copy to become a ".zip" file. You can then extract the .pvi file from the zip file. However, while this is the official method I've been getting odd results.
Source:
Vuforia Studio Enterprise
Greetings,
Source:
Greetings,
Thank you very much for your reply, I've also been getting odd results.
Another question is what if you are leveraging an animation (not a sequence)?  A *.pvi does not appear to be created.
Thoughts?
I can use another format other than PVI for animation, some other developed for example in unity??
