How to rotate a part about an implied axis?
Highlighted
Re: How to rotate a part about an implied axis?
Sure, just send it to -
Highlighted
Well, I sort-of solved it! I noticed that the designers had also created a "stp" file of the part. I imported it into the figure, selected Tools, selected the part, selected Axis, selected part of the circumference of the "circle" that I wanted it to rotate around, clicked Add, selected another part of the circumference, clicked OK, and the axis appeared. Works perfectly!
Then I selected and deleted the original prt file and moved the stp file in the sBOM to the desired spot.
The "only" detail is that if I move the part, the axis remains where it was, rather than moving along with the part! Is there any way to "group" the axis to the part?
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
