In CreoView 4.1 default printer not saving
Highlighted
Regular Member
Normally in creo view once you set your default printer, then creo view remembers each time your print so you don't have to keep selecting. A user is selecting his default printer, but when trying to print in creoview it is showing another printer as default. I assumed he was clearing cache on exiting IE but that was not the case. Has anybody else experienced this issue?
