IsoDraw image transparency problem
Highlighted
Newbie
I am working with TIF files and I need to turn image transparency on. I have created a macro that does this and it seems to work fine. My problem is when I save/export the file out with the transparency on everything appears fine. When I open the file again the transparency is turned off. I have tried not using the macro and manually changing the image transparency to on and then save/export the file with the same result, when I open the file again the transparency is off.
Does anyone know what might be causing this and how I can fix the problem?
I am using IsoDraw 7.1 F000
Thank You for any and all help,
Keith Howard
3 REPLIES 3
Re: IsoDraw image transparency problem
HI Jessica,
Can you upload the Macros you are using to make the TIFF images transperent?
Transperancy in IsoDraw? That is new to me
Transparency in Isodraw? do you mean the transparency in layer tab? the gray scale one?
