Link Solidworks files in Creo Illustrate
SOLVED
Aquamarine
If I create an illustration containing a linked 3D Solidworks file, does it update if I modify the files from SW as would happen with Creo Parametric?
Are there any other alternatives for maintaining the connection?
ty,
Matteo.
Re: Link Solidworks files in Creo Illustrate
As long as you chose "Link" when you imported the source file the illustration will update when a newer version of the source file is found.
There are settings to let you control what happens when a source file is updated, they can be found in:
Options>Global>General>Loading
