Make UNDO actually undo across all of Creo
Re: Make UNDO actually undo across all of Creo - Status changed to: Acknowledged
Are there any plans, in which Creo release this will be fixed?
I'm especially interested that Undo/Redo is affected by certain customization functions and do not understand the logic of CS143895 "However since Pro/ENGINEER Wildfire 2.0, a Pro/TOOLKIT functions called within command access functions (uiCmdAccess) will not clear Undo/Redo buffer. It is a practical requirement that the Pro/TOOLKIT functions which can modify models should not be called while these callbacks are active, in order to prevent instability in the models." .. why it's made such difference between command access functions and other listener functions? This is maybe an easy to change behaviour that would help in many cases (see also this message thread).
I did also opened a case on that topic.
