When Publishing to say SVG or PDF from Illustrate 6.0, the filenames get l-SVG - and .en added, or l-PDF - for the PDF files.
I can't seem to find this anywhere in documentation, but I'd like to stop it if I can. Can this be changed in some config file? I name all my figures to a specific naming structure, but these added characters add more work for me to remove them. I created a script to rename the files that takes a few seconds, but I'd rather not have to do this every time.
The "en" denotes the language and is added to all files except the 3D (pvz).
This is done to identify which file is which language when publishing to multiple languages.
The 3D pvz file doesn't need to language as all languages are in the one file and you can switch between languages in Creo View.
The "I" & "s" denotes where the publish setting that created the file came from, I for a local preference and s for a shared preference.
I'm afraid they are always added to the file names.
Hope this helps.
