Scale an inset to specific value .
Innoptus_Ferry
11-Garnet
When using insets (detail views of part or subassy's) one would expect that the inset cuold be set to a sertain scale. In and until illustrate 6.1 it is not possible to set an inset to a specific scale.
My idea would be to implement and scale factor according to the main imported 3D file.
I would suggest putting this in the ideas section for others to vote on in the community and gauge whether or not this is a feature that others see as valuable.
You can submit it to the Creo Ideas site:
https://community.ptc.com/t5/Addtl-Creo-Ideas-Creo-View/idb-p/creogeneralideas
We monitor the site for ideas related to Creo Illustrate.
Thanks again for your feedback!
Yes,
Thank you! I did so!
Not able to delete this topic unfortunately!
BR
Ferry
We monitor this site for ideas related to Creo Illustrate.
