Use "search tool" for Dimension Properties - Tolerance
I'd like to use TOOLS/Find to search for dimension tolerances like table name H 7 for example.
(properties of hole diameter / tolerance / tolerance table: hole / Tablename: x y)
In my mind it would be nice to find dimensions and surfaces that this table name is added like searching for symbols or pre-/postfix.
This option would give a workarround for coloring sufaces of holes with tolerance H7 (hole basis fit).
Searching for threads is possible so coloring surfaces of holes with threads is possible at the moment.
Re: Use "search tool" for Dimension Properties - Tolerance
exactly my same request. I vote you and waiting for PTC developers answer
best regards
