can't enable background drawing in Isodraw 7.3
I'm running Isodraw 7.3 on Windows 7. Under Preferences/Redraw, the 'use buffered drawing' radio button is not available (greyed out) so I'm unable to display cursor info (snap, element,etc) - any suggestions?
Tags (1)
Re: can't enable background drawing in Isodraw 7.3
Try to switch off OpenGL to turn 'buffered drawing' on. (You need to close all open documents first.)
tried that - no joy...
works fine on nt 64-bit, though...
Scott Allshouse to the rescue....
If your "use buffered drawing" radio button is greyed out and you are running Windows 7:
right click desktop - select "personalize" - select "Windows 7 Basic Desktop".
Problem solved - Thanks again, Scott!
It seems that just need to disable the Windows 7 Aero theme.
