creo view express 3.0 will not open drawing from older wildfire version
SOLVED
Newbie
Can anyone tell me why Creo View Express 3.0 will not open a .drw from the Wildfire version, specifically WF4.0..??
1 ACCEPTED SOLUTION
Highlighted
Re: creo view express 3.0 will not open drawing from older wildfire version
John,
what is Creo View Express 3.0 doing when you open WF4.0 drawing. Does it crash ? Can you attach the picture of Creo View Express 3.0 after opening tha drawing ?
INFO:
Drawing file must contain a viewable of drawing sheet. This image is written inside drawing file, if SAVE_DRAWING_PICTURE_FILE config.pro option is set to EMBED.
Martin Hanak
Martin Hanák
2 REPLIES 2
Highlighted
John,
INFO:
Martin Hanak
Martin Hanák
Hi Martin,
Thanks for your comment, You were right - the SAVE_DRAWING_PICTURE_FILE option in the config.pro was set to NO. i changed it to EMBED like you said and it worked.
First time user of this community chat - and very appreciative of your help Martin..!!
John Kennedy
