wmf/emf export size
wmf/emf export size
Why does the IsoDraw wmf/emf generator double the image size ? When embedded in Word (or any MS app) the image is no longer the correct size and neither are any fonts in the image, which requires the operator to re-size after embedding - an inaccurate solution. It's great that we can produce higher quality lines, but output size is also a serious issue.
Re: wmf/emf export size
Hi Anthony,
this has been improved with IsoDraw 7.3. There you will find an export preference to balance the EMF resolution.
In 7.2 you may set the scale to 50% on EMF export. Then it will not be neccessary to re-size the embedded EMF file. It will be also sightly smaller.
do you mean to say the scaling feature is not available in 7.3? thanks for the quick response, by the way!
You will still be able to set a scale factor on each export in IsoDraw 7.2.
OK...yes or no.... does 7.3 support BOTH emf scaling AND line quality control? I need to know which upgrade to choose.
thanks -
IsoDraw 7.3 has both scaling and quality control.
jeff - great to hear from you - thanks for the direct answer - btw, any plans for a 64-bit version....?
take care -
tony
