Hatching on Creo View
Florian94
7-Bedrock
Hello everyone !
I think it could be great to enable Creo View to display hatching on a section. This is something widely used on the industry and really important for the Model Based Design.
Is there any enhancement on this subject ?
Have a nice day 🙂
If you are under maintenance check https://support.ptc.com/apps/solution_preview/solution/lang/presolution?lang=en&n=CS208090 I am not, so am limited to the problem description.
Thank you for your answer !
At the end of the article it's explained that Cross-Hatch is exported (in .pvz) as a "Cosmetic Geometry". But Cosmetic Sketch Properties is not supported by Creo View Adapters ..
So it seems there isn't any solution .. unless PTC enable Creo View to read Cometic Properties..
VeqTor
(To:Florian94)
It is a severe limitation that sections can not be hatched in Creo View.
This feature really should be added.
romorrison
(To:VeqTor)
The idea to support this enhancement has been created here:
https://community.ptc.com/t5/Addtl-Creo-Ideas-Creo-View/Hatching-on-Creo-View/idi-p/558431
It would be good to up vote this if you feel it's an important enhancement.
