Allow "Make read only" to be set as default for conflicts
Currently the setting Continue is the default setting when the save operation encounters parts that Creo Parametric thinks need to be modified upon regeneration.  "Make read only" is not available as a default setting.
PTC, please allow "Make read only to be set as default.  Also, fix the failure on save problem when objects are marked as read only on the fly.
Reference:
Setting the value of "Make read only" as a configs option for dm_checkout_on_the_fly in Creo Parametric
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS44903&art_lang=en&posno=2&q=%22make%20rea...
Saving issue
https://www.ptcusercommunity.com/thread/57191?&art_lang=en&posno=10&q=%22make%20read%20only%22&sourc...
Creo Elements/Pro fails to save when components are set to "Read only" during save operation
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=10183831
Save in Pro/ENGINEER fails when objects are set to Read Only during save operation
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=10216950
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=10222468
Save fails when components are set to read only during save operation
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=12412875
What is the difference between messages "The object is read only as it is not checked out" and "Model is Read Only" when attempting to save in a Creo session linked to Windchill
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS45765&art_lang=en&posno=1&q=make%20read%2...
1 Comment
Level 10
"Also, fix the failure on save problem when objects are marked as read only on the fly."  This impacts us all the time with newer users and even experienced uses who don't quite understand why they can't check-in when they have a bunch of locked modified files conflicting. It just doesn't make sense to make the changes and then make it read only. A lot of our users also have a relatively bad habit of opening by directly typing the filename into the open box which then doesn't give you an opportunity to lock the objects.
