Piping - Existing radius don't update after line stock replacing or updating
fbertolino
1-Newbie
Our firm heavily uses Creo Piping features to produce true pipes by CNC machines. I'ts common to have a pipeline that changes its size during the design, eg. from 1/2" Dia. to 5/8" Dia. This change is quite easy by the command "modify pipe", everything but not the existing radii: why? You can't phisically bend a 5/8" pipe with 1/2" or, worse, 1/8" radius. If you want to set the new radius you have to identify and do it manually one by one.
Here follows the explaining PTC document
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS73811
Please let all the parameters of the line stock affect the pipeline after replacing or updating.
A new config option will save a lot of time.
0 REPLIES 0
