Today there is no reasonable possibility to create solid geometry of cables or harness parts.
PTC only refers to a workaround by using other data exchange formats:
But this workaround breaks the parametrization and thereby is not a preferred solution.
PTC should provide a better possibility (parametric) to create solid geometry of cables/harness parts!
