2 projection Curves
MarkWestcott
2 projection Curves
I have been out of the saddle for a while but am jumping back in headlong into Creo 2.0. I can't find out to do a 2 projection curve. Are these still available in Creo 2.0?
Thanks in advance.
It's called Intersect now. Select both sketches and then select intersect in the 'Editing' portion of the 'Model' tab.
LinkedIn
5 REPLIES 5
LinkedIn
Slight semantic correction
Model tab
Modifiers
Intersect
Thanks for the help.
Modifiers in assy mode, edit in part mode. Why the difference? I dunno.
LinkedIn
Right again!
Thanks Doug
I noticed, in WF3 I believe, that they significantly changed the way it works, and in my opinion it doesn't work as well or accurately. I've had times where the intersection of 2 curves did not exactly match the 2 projections, and I instead had to create a curve from the intersection of 2 extruded surfaces. Fair warning.
