2d editing
ptc-2490810
2d editing
How can I delete a certain segment of a line which is crossing over another line? IE, if I have a circle and a line passing through it, I want to delete one side of the circle with the deletion ending at the line so an arc is created. Thanks!
2 REPLIES 2
Not applicable
(To:ptc-2490810)
Split the 2D edge at the intersection, then delete the parts you're not interested in.
Not applicable
(To:)
Here's a screenshot which shows where you can find the ""Split"" command.
