Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
How can I delete a certain segment of a line which is crossing over another line? IE, if I have a circle and a line passing through it, I want to delete one side of the circle with the deletion ending at the line so an arc is created. Thanks!
