45º chamfer text option...
PAULKORENKIEWIC
We are using Wildfire 3.0 build M080 and have been trying to make the 45º chamfer note text format be "<linear dimension="> X 45º", however we only seem to be able to get "45º X <linear dimension=">". In other words, what we want is something like "3.5 X 45º" but all we seem to be able to get is "45º X 3.5". Makes no difference to me, but the powers that be around here would like to see it they way they want. My understanding is that there is one setting in the DTL file: CHAMFER_45DEG_DIM_TEXT which I have set to "iso/din", however that produces the "45º X 3.5" type dimension. The other value for CHAMFER_45DEG_DIM_TEXT is "jis", but that also produces the "45º X 3.5" type. The Help Center shows the following which looks like the "iso/din" would produce the dimension we want, so where are we going wrong? Or is this just another PTC "bug"?
Paul Korenkiewicz
FEV Engine Technology
4554 Glenmeade
Auburn Hills, MI, 48326
0 REPLIES 0
