Dear Fri's
Did anyoone know how to assign auto save option? in creo/elements pro5.0
Advance thanks for sharing the information.
Thanks & Regards
Viswanathan.K
That is great Antonius!!!
Martin how to install it , I am getting error
Foreign program "SuppUtils" failed to initialize: error PRO_TK_NO_LICENSE
Message from foreign program: "License not found. Your MAC addresses are 70-F3-95-02-10-74;70-F3-95-02-10-75;"
you will receive an email from my colleague Jiri Poledna.
Martin Hanak
Hello Martin,
Jiri solved my problem.
Thank u very much both of you.......
Is this still available? The link isn't working today, although I did visit the web site recently, I believe. I sent an email to the company and received no response.
Try this...
set English language (top left corner)
Products > Supputils
Currently I am testing "license problem (RAJENDRA KADAM)"
Martin Hanak
Sorry, still not working from here, the connection times out.
Doug,
what is not working ... http://www.cogras.cz ???
You can test
>>> ping www.cogras.cz
>>> tracert www.cogras.cz
My results:
C:\Users\mh>ping www.cogras.cz
Pinging www.cogras.cz [95.168.203.12] with 32 bytes of data:
Reply from 95.168.203.12: bytes=32 time=10ms TTL=119
Reply from 95.168.203.12: bytes=32 time=8ms TTL=119
Reply from 95.168.203.12: bytes=32 time=7ms TTL=119
Ping statistics for 95.168.203.12:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 7ms, Maximum = 10ms, Average = 8ms
C:\Users\mh>tracert www.cogras.cz
Tracing route to www.cogras.cz [95.168.203.12]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms charon [192.168.43.250]
2 2 ms 1 ms 1 ms 46-33-127-249.infos.cz [46.33.127.249]
3 7 ms 1 ms 1 ms 46-33-112-65.infos.cz [46.33.112.65]
4 2 ms 2 ms 2 ms ms.bsc-net.cz [212.24.154.73]
5 6 ms 6 ms 6 ms cz-prg-76ttc-ten1-3.dialtelecom.cz [82.119.245.201]
6 6 ms 6 ms 6 ms cz-prg-cr1-kkk-10ge2-2.dialtelecom.cz [82.119.245.142]
7 * 6 ms 6 ms cz-prg-asbr2-kkk-te1-3.dialtelecom.cz [82.119.246.26]
8 6 ms 6 ms 6 ms nix5.superhosting.cz [91.210.16.145]
9 8 ms 6 ms 6 ms ttc-c65a.vl7.superhosting.cz [88.86.96.153]
10 6 ms 8 ms 10 ms unn-95-168-203-12.superhosting.cz [95.168.203.12]
Trace complete.
Martin Hanak
No good from here:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
1 1 ms <1 ms <1 ms [removed]
2 1 ms 1 ms 1 ms [removed]
3 66 ms 13 ms 13 ms [removed]
4 14 ms 13 ms 13 ms xe-8-0-0.edge2.Washington4.Level3.net [4.53.114.9]
5 124 ms 124 ms 124 ms vlan80.csw3.Washington1.Level3.net [4.69.149.190]
6 126 ms 126 ms 127 ms ae-82-82.ebr2.Washington1.Level3.net [4.69.134.153]
7 126 ms 128 ms 125 ms ae-42-42.ebr2.Paris1.Level3.net [4.69.137.53]
8 125 ms 124 ms 123 ms ae-46-46.ebr1.Frankfurt1.Level3.net [4.69.143.137]
9 124 ms 124 ms 134 ms ae-81-81.csw3.Frankfurt1.Level3.net [4.69.140.10]
10 126 ms 126 ms 126 ms ae-82-82.ebr2.Frankfurt1.Level3.net [4.69.140.25]
11 124 ms 124 ms 124 ms ae-5-5.car2.Prague1.Level3.net [4.69.135.50]
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
Doug,
if you (or someone else) are interested in Supputils, then send request for DEMO via email to support@cogras.cz.
FYI I do not have any idea, why you cannot connect to www.cogras.cz
Martin Hanak
Thanks Martin. I had been able to access your web site, in fact had sent in inquiry about Supputils a month ago through it to your 'info' address and never got a reply. I sent another just now.
There was a problem that access from some internet providers in some countries has been blocked to cogras.cz. Now it is working again correctly.
