Absolute accuracy recommendation for consumer electronics
dmartin
11-Garnet
Everyone,
We could use some advice regarding what other companies, particularly those in consumer electronics, are using for accuracy values in Creo. We've been using relative accuracy as a default, and of course that comes with a lot of issues. We're exploring values for absolute accuracy, and we thought to reach out to the community to hear your experiences. We've heard that Motorola, for example, uses 0.003 mm. Can anyone share what you're using and successes and failures from your approach? Thanks in advance.
David R. Martin II
Senior CAD Application Specialist
Amazon
7 REPLIES 7
.001 mm absolute is what I have been using for tiny parts
We are using 0.005 mm.
Best regards
Bjarne Frandsen | Technology Specialist, MCAD
Phone: +45 9684 4825 | Email: -
[cid:image001.png@01CDCC9C.5B8352F0]
Bang & Olufsen A/S | Peter Bangs Vej 15 | DK-7600 Struer | Denmark
www.bang-olufsen.com
dgschaefer
(To:dmartin)
I've been using 0.0001" / 0.00254mm (the default when choosing absolute accuracy) for everything since I started on Proe back in 1996, rev. 16. It has generally served me well; I've had few occasions where I needed to tweak it. My biggest accuracy related problems have been with files created with relative accuracy.
LinkedIn
Hi Dave - we make injection moulds and have been using 0.0002" (0.005mm) as
our default accuracy for 15 years.
Regards
Gary Pitt
Columbia Plastics Ltd
19320-60th Ave
Surrey, B.C.
V3S 3M2
604 530 9990 Ext 236
Discussion of absolute accuracy should include the typical part size, no?
John
Same here, .0002” absolute accuracy for over 17 years now… with an occasional deviation by a .0001” to either side… we stay clear of relative accuracy.
Paul
Paul Mailloux Cad/Cam Applications Engineer
NyproMold, Inc.
144 Pleasant St, Clinton, MA 01510 ▪ www.nypromold.com
In Reply to John Moody:
Yes and no, it has to do both with the size of the part, and the size of the smallest features you want to include with them. These features create small vertices and curves which affect part stability. We make sheet metal parts and use about 0.0025" (the smallest size typically available given our dimensions).
