Is there any way to add new supplier in the EMX supplier list? Or is there any way to create our own supplier in EMX? Can anyone help me to solve this......![]()
There are three steps to add new suppliers to EMX component library:
I have already tried first two steps, I cant understand the last step? By duplicating d-m-e folder, I created a new folder wherever the d-m-e exists in the component folder. I have also added that folder name in "supplier.txt" file. How to update the data in "comp_data.txt"??
A recorded video for adding a supplier has been uploaded.
The content of the new supplier will exactly the same to the copied one. We will have to update the component data file to fit your requirements. A description doc for the data file is available with the link below.
Thank you for your reply sir
. I tried duplicating components it worked but I want to add a new assembly in existing mold base assemblies i.e in mm/component/asm because I need only specific set of plates in the new assembly. While clicking load asm button in moldbase definition box I need that new assembly in the supplier list. Please help me to solve this
Adding a new moldbase supplier is a different story. It's a bit different to component.
Take a look at this video: add_moldbase_supplier.mp4
Hello Shanmuga,
did Russel's advices help you solve your issue?
If yes, can you please mark the post with the most relevant information as "Correct Answer"?
This will help the community to see, whether the question is answered or assistance still needed.
Gunter
Hello Koch,
I tried the method shown in the video but I cant save the new file either overwrite it, If I type a new name and click save it is not saving in that list, but the method is useful. I cant locate the problem hence I did not replied yet
Shanmuga..
I tried once and it was a success. I can help if you can share further more details(model or dimensions).
Dhinesh
Ryan Kelley: Can you please move this entry to the group Expert Moldbase Extension - EMX
