Does anyone have a list of all of the alt key shortcuts?
Hello Joshua Fontana,
Once you press the Alt key the menu bar will be highlighted and one letter will be with underscore i.e. the short-cut for getting sub-menu in the that menu bar. The procedure will same for sub-menu's. by pressing Alt+letter the tool will be activated.
Ex :
1. suppose for closing a document from 'n' number of documents
short-cut : alt+f --->c ---- then the active window will be closed.
2. suppose for changing the orientation in the window like from isometric to trimetric view.
Short-cut : alt+t --->e ---- environment tool settings will appear on screen.
Thanks & Regards,
Naveen Kumar Gongu.
