Annotation in WF4
JaikumarRangasw
Annotation in WF4
I am Not able to view the annotation note on the model even though annotation display is turned on.Any one pls clarify.
2 REPLIES 2
You may need to turn on 3D Note Display. If you don't see it in the icons you can add it using Customize Screen. It's under the Commands tab and the View category.
Hi Kevin, It's working.But I did'nt understand why the note display is also controlled thro' another icon 'Annotation display'.Any ways thanks for the solution. Regards, Jai[/quote]
