Hi All
We are planning to upgrade our system to Windchill PDMLink 10.2 and Creo 3.0
Just want to find out if there is anyone out there doing this, and if they have any issues and recommendations
Cheers
David Connor
David,
in http://support.ptc.com/WCMS/files/67180/en/CreoDataManagementCompatibilityRoadmap_090914.pdf document, you can see info that there is Compatibility with PTC Creo 3.0 F000 & 10.2 M020.
But ... it is your own risk, if you use F000, M010, M020 in production environment. These early releases used to be "problematic".
Martin Hanak
creo 3.0 has some bugs
David,
Martin Hanak
Hi There
I think it's to early to install Creo 3.0 ... lot of bugs ... wait release M030 at least
We are live with PDMLink 10.2 M020. But i only have Creo 3.0 M010 installed for testing purposes. I dont see us going live until sometime after M030 is released.
