how can i wright in Arabic font? I've tried to download font but it didn't work ? creo separate the litter away from each other
try config option font_dir set your required font directory, and see it works or not?
I have run into this with the Hebrew front as well. The only solution is to make each their own single character entity and place them as you would have them be.
If PTC ever adopts the power of an actual Microsoft editor in CAD, we might get intelligent text. Until then, we have to fend for ourselves.
do you have a video or instruction explain your solution? I could really understand what do you mean by (make each their own single character entity and place them as you would have them be.)
