Assly in WF-3
ptc-1654405
Assly in WF-3
How to assembel components by using co-ordinate system if components and assy having lot of co-ordinate system? select by list is not helping me. like in pro 2001 we can select by menu and selection of co-ordinate system is very easy. Can some one help me ?
4 REPLIES 4
It's better if you give a relevant name to the co-ordinates, so that u can easily find out when u r usint the component.
If i have more co-ordinate systems say 50~60 . i want to know the selection method like it was in 2001 select by menu.
try using the search tool. It would be a good thing to use in this case.
Thanks mr.Susie I think this will solve my problem. By the way you can contact me on ngupta@reva-ev.com.
