I came across this term on the internet and am trying to learn more about it. I am using Wildfire 5.0 and would like to activate it if possible.
CONFIG option
autobuildz_enable <yes>
I have to admit here that I am basically self taught on pro/e. I have done very few modifications to the standard setup. I opened pro/e went to tools, options, but am not seeing what I was expecting per above. I am probably in the wrong place. Can you help me further with more detail of where I need to make the change I would appreciate it.
I forget, but it may be a hidden config option (in fact, I'm sure of the availability in WF5)
Close your session of PRO/E
Open your CONFIG.PRO file in a text editor
Type autobuildz_enabled yes
Save and Close the CONFIG
Launch PRO/E
One method to verify is if there is a std.out in the start in directory, open it (text editor) and see if there are any messages related to autobuildz
Config.pro may be in multiple locations so only modify 1 of them.
If you want the option company-wide, use the config.pro in the <PTC Loadpoint>/text folder.
If you only want the option for yourself, modify the config.pro file in the icon shortcut Start-In folder. (This folder should be on your local hard drive and not across the network or the <PTC Loadpoint>!)
If it is a hidden option, you can still add it from Tools-Options, just enter the 2 values manually.
Okay, now that I have got it loaded and enabled are there instructions anywhere? Feature is supposed to assist in taking 2d to 3d.
This will get you started...
Anything further I suggest searching the Knowledge Base for AutoBuildZ, where there is a lot of information about it.
