Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Hey everybody, Is there anyone out there that might have an truck axle model? I am looking for a Dana 44 front and/or Dana 60 rear. I am working on a side project and was going to be needing that. I don't need the gearing or axle shafts unless that is included. Any help would be greatly appreciated.
