Bending customised tubes in Creo 2.0
ptc-4376890
Hi all,
I'm designing a Formula Student chassis as a final year project to be used at next years event. However, I have come across a problem. Using a discussion I found on here from April 2013, I have managed to add the tubing as per the event rules, but it said that it was only for straight tubes. Is there any way of bending customised tubes to be used for the roll hoops, or is it a matter of just using the closest existing tube?
Thanks a lot,
Tim
3 REPLIES 3
The best way to do this is to use AFX (Advanced Framework Extention) if you have a license.
That's what I'm using; the framework section of the AFX/EFX
You will need to create your datum sketch with the curve in it.
