We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
Is it possible to calculate the bending moments and other properties of a cut from a solid model of a mechanica calculation?
Helena,
I'm not sure what you mean by "bending moments of a cut".
Can you explain your requirements in a little more detail, maybe with some pictures?
What I mean is: Is it possible to integrate the stresses of a cut (any cut) of a structure, so that you achieve the resultant forces and moments of the cut?
I don't think this is possible to do exactly as you describe.
However, it might be possible to use Info -> Review Total Load, perhaps with a coordinate system created at the point of interest.
It may also be possible by creating your cut and applying only the loads on one side, and creating a Simulation Measure on the cut surface - but I'm not sure whether a measure type exists that will give you bending and shear forces.
