Bold for a line of text
rdonovan
3-Newcomer
Users,
I have a set of notes 1-10 and I would like to bold a single line without having all the lines of text bolded and I would not like to have a separate note of text bolded and placed within the original note. Is there anyway of doing this?
Rick
rdonovan
3-Newcomer
(To:rdonovan)
Thank youLaura & Sean both methods worked
In Reply to Rick Donovan:
Users,
Rick
davehaigh
(To:rdonovan)
Use curly braces to separate that line of text.
For example this note:
This is normal text
{1:This text has been seprated with curly braces}
This is normal text again
Will allow you to select the middle line of text by itself and assign a different font to it.
That results in a note that looks like this:
[cid:image003.jpg@01CC9887.0005D190]
David Haigh
