CREO2 M110
Inoram
CREO2 M110
Is downloading....
15 REPLIES 15
Make sure you let us all know how that works out.
Inoram
(To:JamesBurcham)
So far, so good. They fixed the huge performance hit when creating assembly sections.
Inoram
(To:Inoram)
Ok, I was wrong, that's not fixed...
Inoram
(To:JamesBurcham)
At the moment, I would say if you are on m100 and you don't see something specifically fixed in the Update Advisor that you need, stay on m100. My opinion anyway. I have seen some flakyness with m110. I will run it a bit longer, but possibly go back to m100.
Inoram
(To:JamesBurcham)
Ok I am back on m100. Too many power exits and fatal exceptions in one day for me.
TomD.inPDX
(To:Inoram)
This is really disturbing!
Inoram
(To:TomD.inPDX)
Agreed, and it takes a lot for me to back down a build. But m100 I THINK might have crashed once in what 6 weeks or more? and m110 multiple times in one day, nope nope nope...
Mahesh_Sharma
22-Sapphire I
(To:Inoram)
Matt,
Initially there were issues, now it can can download.
BuddyHudson
(To:Inoram)
Wow, still no fix for the datum plane, csys, and point display issue...lame!
Inoram
(To:BuddyHudson)
Which one is that?
BuddyHudson
(To:Inoram)
The fact that you have to comment out display options for datum display to show....just ridiculous!
!display_coord_sys
!display_axes
Inoram
(To:BuddyHudson)
oh? I haven't seen that one, is that in the config.pro?
BuddyHudson
(To:Inoram)
Well, it has to do with having datum display options for planes, points, axis, and csys in the config.sup. I resolved the issue by moving the options into the config.pro.
Half of the our mapkeys do not work on M110. Goind back to M100. Frustration is high again.
Danilo check out this post about mapkey syntax:
http://communities.ptc.com/message/246245#246245
