Can I save file in Creo 3.0 to the version Creo 2.0?
lbristot
2-Explorer
Leandro,
see also compatible of CRO 2.0 with Wildfire 4.0
Martin Hanak
Martin Hanák
7 REPLIES 7
Not a direct option, GCRI can be used for the same.
Refer earlier post Re: 3.0 to 2.0
What did you mean with "GCRI" ?
GCRI > GRANITE-Based Cross-Release Interoperability
Creo files are not backward compatible, files created in higher versions cannot save to open in older versions.
As in earlier post, there is a DLL which can use to open higher version file in lower version. File open in lower version will hold all features, however features from higher cannot modify. New features can create in lower version.
Leandro,
Martin Hanak
Martin Hanák
Leandro,
Does any of the earlier replies help you to import files in earlier version?
Yes Mahesh Sharma. Thanks for you attention.
Leandro,
You may mark appropriate replay as correct answer for the post.
