Can Pro/E look into multiple PDM systems at once?
JohnMattson
2-Explorer
Is it possible for Pro/E to see into two PDM systems at the same time?
I know you can't have two "active" servers at once, but could one be
active and the other behave sort of like a search path?
We are looking at both PDMLink and ProductPoint. PDMLink to store the
released data and ProductPoint to be the work-in-process (WIP)
environment. What we want is for a Pro/E session to view ProductPoint
as the active server, but still be able to look into PDMLink for
read-only access to enterprise-level released content. We'd rather not
duplicate the enterprise-level released content back into ProductPoint
if we didn't have to ~ if that is even possible...
Any thoughts?
Thanks, John
This electronic message including any attachments ("Message") may contain information that is privileged, confidential and/or exempt from disclosure under trade secret and other applicable law. If you are not the intended recipient, notify the sender immediately, permanently delete all copies of this Message, and be aware that examination, use, dissemination, duplication or disclosure of this Message is strictly prohibited.
0 REPLIES 0
