I tried recording it and nothing got recorded so I am guessing not. Has anyone played a trail file or otherwise deleted a mapkey?
Currently I am loading back in a blank mapkey over the top of the old mapkey which effectively deletes it. It still leaves it in the list of mapkeys though.
I think it can, look at this example:
mapkey $F6 ~ Command `ProCmdUtilMacros`;\
~ Select `mapkey_main` `list_mapkeys` 1 `$F6`;\
~ Activate `mapkey_main` `DeleteButton`;\
~ Activate `mapkey_main` `CloseButton`;
It opens macro dialog, selects the desired mapkey, deletes it and close dialog box.
Just replace $F6 with your own mapkey name in line 1 and 2.
Jose.
You should be able to delete a mapkey in the dialog box. Remember, you must then save your mapkeys to keep the change.
You can also delete lines out of your config.pro file.
Jose.
Did you pull that from the trail file or coerce the mapkey to record it?
Asking for a friend.
Yes, I did the cheating, I copied it from the trailfile.
Awesome. Thank you.
